Super A info request
VAJerry
05-29-2005 10:09:24
Need to know clearance from bottom of tranny to ground within 1/2". Thanks.
Hugh MacKay
05-30-2005 03:02:07
 Re: Super A info request in reply to VAJerry, 05-29-2005 10:09:24
Jerry: I could go out and measure all 3 of my tractors and will come up with 3 different figures. I have 3 different size rear tires on the 3 tractors. Super A has 9.5x24 about half worn, 140 has 11.2x24 half worn and 130 has 12.4x24 half worn. I know there is at least 3" difference between SA and 130. You stated you wanted this within 1/2", there could be close to an inch between new and worn tires on any given tire size. From what I've given you, let me know and I will measure which ever tractor you wish. Can get all 3 if you wish. I will be away all day, but can get back to you this evening.
Harold H
05-29-2005 14:26:33
Cultivating clearance is listed as 21 5/8" in original IHC specs but this is probably the clearance under the front axle. It would be more to the bottom of the transmission.
Harold H
