Farmall H jumps out of 5th gear
Mike S 806/H
05-29-2005 12:19:43
I have a H that jumps out of 5th. I just had the cover off, replaced all the springs in the forks and all the bearings are good Gears look excellent. anything I missed? If I hold the shifter in 5th its stays in.
little h
05-30-2005 04:29:17
 Re: Farmall H jumps out of 5th gear in reply to Mike S 806/H, 05-29-2005 12:19:43
replace your shifter. mine was worn and did the same thing....replaced and it works perfect....
Jon Older
05-29-2005 18:43:07
My H jumped out of both 4th and 5th gear, after flushing the transmission twice with kerosene (and getting a ton of gunk out) and adding fresh 80w90 oil, the problem was fixed! I have no idea why or if just a coincidence but it worked.
Haas
05-29-2005 13:42:25
As Cowman says, your 5th gear likely has the teeth almost worn off. The teeth on the 4/5th sliding gear for 5th gear are on the inside of the gear. You can't easily see the teeth.
Nebraska Cowman
05-29-2005 12:58:21
The gear that you can"t see because it meshes inside the top front gear. the teeth get worn off.
