clunk sound coming from left rear
nec
05-29-2005 12:46:38
soft sort of clunking sound coming from left rear...seems to reverberate thru the tire...bearing? not a consistant sound but is doing it quite regular now
Phlogiston
05-29-2005 19:28:38
 Re: clunk sound coming from left rear in reply to nec, 05-29-2005 12:46:38
See if it happens once or twice every revolution of the rear tire. If it does, then I think it might be a tooth missing off the bull gear.
Phlogiston
VAJerry
05-29-2005 12:54:33
Whats it on? Check wheel clamps/lug nuts.
nec
06-09-2005 05:03:33
 Re: clunk sound coming from left rear in reply to VAJerry, 05-29-2005 12:54:33
farmall super c...one of the rims has shifted and moved in but its the other side thats maiking the noise...if I push back and forth on the tires itseems to be loose...will the hub make that much noise if loose? I know, dumb question...just don't want to have to tear it apart and find thats what the problem was.
Sloroll
05-29-2005 12:53:58
Occasionally I get a sound from my left rear too... But on the tractor make sure your wheels are tight. I tore the heck out of my 504 only to finaly figure out the wheel wedge was loose.
