Proper installation of safety wire on main bearing
David in UT
05-29-2005 14:53:25
Hi,
I'm assembling the motor for a '40 M, and I've gotten to the point where I need to install safety wire on the main bearing cap bolts...something I haven't done before. Any suggestions on the right and wrong way to do this? I get the part about wiring them to pull tighter as opposed to looser, but beyond that, I'm making it up...
Thanks,
- David
El Toro
05-29-2005 15:46:47
 Re: Proper installation of safety wire on main bea in reply to David in UT, 05-29-2005 14:53:25
You have the right idea. Just twist the wires together and make a nice it nice and snug. You run the wire through one of the bearing caps bolts and have it long enough to reach the other bolt. When you finish the twisting and then run one of the wire ends through the other bolt head
and pull the twisted wires tight and twist the wire again to secure it. 5 or 6 twists should be enough. Then cut off any access wire. We called this lacing. Hal
