560 Trans ??????
560puller
05-29-2005 15:28:05
There are two covers on the bottom of the trans housing that bolt on,my question is can the gear and shaft that drive the hydraulic pump be taken out through these holes or do I have too split the tractor.If it has to be split does it split between the engine and trans or trans too rearend?I built this tractor as a puller and it has a rattle on under the T/A which is new I suspect the bearing on the hydraulic pump drive shaft but who knows? Thanks for the help. 560puller
Aces
05-29-2005 17:19:38
 Re: 560 Trans ?????? in reply to 560puller, 05-29-2005 15:28:05
560puller. You can't do much the bottom plates. If you need to change the PTO and hydraulics pump drive you will have to split the tractor at the clutch housing right behind the engine.
