MD engine/Galion grader
Joseph Johnson
05-29-2005 17:29:06
Thanks to you guys for the info. I should say that all that matters is the bolt pattern for the bell housing. The front mount will change over. Leaving the rear. As long as the bolt pattern is the same I can use the MD engine. The engine sits on the front/rear mounts clear of everything else. From what I have come up with it is an H engine in the grader. Don't get me wrong I could unbolt both bell housings and take measurements to know for sure. Or you guys may just know. Thanks again.
CNKS
05-30-2005 06:34:04
 Re: MD engine/Galion grader in reply to Joseph Johnson, 05-29-2005 17:29:06
One thing to keep in mind is how it will be used. If you match the use to the power of the MD, chances are you are going to break the H transmission/rear end, provided that's what is in it.
old
05-29-2005 19:31:55
What model galion grader is it?? I have a model 303 which has the same engine as the 560/660 tractors. Heres a phone number also for a place that may be able to help you. 740-439-5512. He sure helped me with parts and answers to questions
