986 Tranny Trouble
James from PA
05-29-2005 18:03:25
I have a 986 that gets stuck in high range. When you go to take it out of high range the shifter handle moves to neutral but it stays in high. If anyone could help shed some light on this problem I would appreciate it. Thanks.
James from PA
05-30-2005 05:45:05
 Re: 986 Tranny Trouble in reply to James from PA, 05-29-2005 18:03:25
Thanks for the help. I'll call the mechanic tomorrow. Thanks again.
steve aeschliman
05-30-2005 04:45:39
james, jjk is right about needing special tools to remve and install the range tran. cover unless you do not have a aux. fuel tank then you can remove the reverse idler cover on the left side to enter the reverse shaft in the fork. i hope this helps steve
JJK
05-29-2005 20:04:32
You probobly still have the original lever on the range cover which is under the seat. These levers wear out were it bolts onto the shaft that goes into the cover. Take the floor plate off, look under the seat, and move the shift lever from high to low and watch the lever on the range cover and you'll see what I mean. Ag Parts and Hy-Capacity have a redesigned lever and shaft for replacing the OEM lever. Anyway thats where your problem will be and its best to have somebody thats done a range cover before either do the fix or at least help you out if you've never been in one before. There's a tool for pushing the reverse shaft down while lifting the cover so the half moon key don't fall out from down below and another tool for holding the spring on tight when installing the cover so it don't fall off.
steve aeschliman
05-29-2005 19:59:02
the detent on the shifting shaft is wore out in the range transmission. needs a shaft detent arns and rollers. the cover needs to be removed under the seat through the cab.
