300 hydraulic problem
Jon Older
05-29-2005 18:36:35
My 300 seems to have lost most of its hydraulic fluid after a long day of putting fence posts in. There are no external leaks and the pump works fine when when tanked up. I assume it has a leak into the engine via the timing gear? If so, is it a major problem to fix , and will it leak less if the pump is not used so hard? Thanks in advance!
Kit Gage
05-30-2005 13:41:00
 Re: 300 hydraulic problem in reply to Jon Older, 05-29-2005 18:36:35
Same thing happened with me. Installed a speedi sleeve and seal - so far so good. 4 years of rather easy work.
Good luck
Hammerheadd
05-30-2005 05:43:25
If it were leaking into the engine it would be "making oil" check the engine oil level. If it is overfull you found your leak.
TDK
05-29-2005 20:28:23
Jon, if it were mine I'd replace the seal and put a wear sleeve on it. Seal and sleeve will probably cost 20 - 30 dollars. Most of the time this will work for many years and it's a great deal less expensive than a rebuilt pump.
PAULIH300
05-29-2005 19:41:58
Sounds like the seal is gone.Replacing it without a wear sleeve means you'll be taking it apart all over again.If the tractor is in good shape,I would buy a new pump.$400 or so but worth it.
