not enough rpms?
Ben Rauls
05-29-2005 18:43:27
Ran my 47 m on dyno, and could not get 540 pto. Guy running the dyno said it was to low. I imagine its a governor problem. i took the governor cover off , not running throtle closed, the spring is loose.Is there some adjutsment, or is it the wrong spring? Thanks for all the help...
Ben
Hayfarmer
05-30-2005 09:17:16
 Re: not enough rpms? in reply to Ben Rauls, 05-29-2005 18:43:27
I would replace the spring on the governor first, may not be holding the throttle open. Other possibilities, or maybe a combination, the throttle linkage may need to be adjusted or the stop bolt in the governor is set too far out not allowing the governor to open.
riverbend
05-30-2005 05:24:11
The spring is supposed to be loose at closed throttle - you can feel it pull back as you pull on the lever.
Could be out of adjustment and / or an weak spring.
