DT 466
billyiron
05-30-2005 08:31:47
I have this engine on a irrigation well,the well load is about 120 hp, the engine has really started to smoke quite bad, Ive redone the injectors and pump,had the valves set,checked air intake,new filter, turbo boost ok,does not use any oil,seems to have the power but does seem to be laboring more than other 466s we have pulling the same or larger loads,this engine has about 7000 hrs on an IHC shop OH,,,,help thanks billy
steve aeschliman
05-30-2005 20:03:21
 Re: DT 466 in reply to billyiron, 05-30-2005 08:31:47
Billyiron, If the intervance, (internal timming advance) is stuck or not advancing the engine would labor and smoke. the Starting would'nt be affected. Steve
ejr-IA.
05-30-2005 09:38:24
Are you getting a flat cam on the lobes ?
billyiron
05-30-2005 10:10:15
 Re: DT 466 in reply to ejr-IA., 05-30-2005 09:38:24
You know I didnt think about that,and I dont know if they put in a new cam or not,,thanks for posting ,Ill check on that,,,billy
