Super M char-lynn power steering ossillating
kitchenr
05-30-2005 16:29:18
Tell me were I went wrong. I had a seal leaking in the char-lynn steering motor. I removed the motor and replaced the seal, filled with fluid and now the steering ossillates.
BIG JOHN
05-30-2005 18:06:26
 Re: Super M char-lynn power steering ossillating in reply to kitchenr, 05-30-2005 16:29:18
When you reassembled the torque motor you got it out of time. You can either take it back apart and get it back in time or just change the inlet hose to the outlet port and vise, versus. Sometimes this swap will to the trick and sometimes it doesn't, and you have to tear it down and reassemble it the right way.
kitchenr
05-31-2005 11:07:32
 Re: Super M char-lynn power steering ossillating in reply to BIG JOHN, 05-30-2005 18:06:26
Reversing the lines worked. Thanks a ton.
