1086 air-conditioning
Tom F.
05-30-2005 17:27:54
Does anyone know where I can get a wiring diagram for an IH 1086? I recently replaced the compressor and few hoses and now I'm having electrical problems as the compressor clutch won't stay pulled in. Also, does anyone know what the piston and spring device is in the liquid line at the bottom of the cab? Thanks.
steve aeschliman
05-30-2005 18:38:07
 Re: 1086 air-conditioning in reply to Tom F., 05-30-2005 17:27:54
tom, the spring and piston in the line is to disconnect to the hose when putting in a torque or clutch. If you converted the system to r134 the high pressure is higher and it is best to replace the pressure switches with higher pressure or a binary switch on the high side to take care of low and high pressure. Hope this helps. Steve
