Problem fixed thanks to you
ToddH
05-30-2005 17:42:50
I just wanted to thank all that helped get my Super C running again (symptom shown at bottom). Until one of you pointed it out, I did not know there is a second fuel filter (the ¼” diameter cylinder shaped screen that goes into the carb). When I cleaned mine, it ran much better (about 20 min before stalling). I then installed new plugs, cap & rotor, points and condenser and now she doesn’t miss a beat! A neighbor told me about this great discussion forum and this was my first experience, which I am grateful for. I am also more grateful than words can say for those of you who are veterans who have secured the freedoms of all of us! Todd
08:57:28 05/28/05
My 53 super C starts good but after only ten minutes, it dies. If I disengage the mower as soon as I hear that it is about to stall, it will continue running but only if I then throttle it down near idle. After letting it sit for (turned off) for about 15 min, I can start it and mow again for about 5-10 min. I opened the fuel filter bowl and cleaned the screen and also put in some concentrated carburetor cleaner but it did not help. I assume that it is the carburetor but I am hoping someone will guide me with suggestions. Thank you in advance for any comments. Todd
Nebraska Cowman
05-30-2005 18:20:48
 Re: Problem fixed thanks to you in reply to ToddH, 05-30-2005 17:42:50
Hey ToddH we are going to expect to see you around here often now!
riverbend
05-30-2005 17:54:17
Good to hear that you got it sorted out.
Greg
