auxillary tank repair / replacement
Kevin Brooks
05-31-2005 06:55:30
After thoroughly cleaning the insides of my M's auxillary tank I discovered a 'ring' of holes ~1/4 way up from the bottom - just about the level where the dirt, dust and other crud had built up to and sat for umpteen years. I've plugged most of the holes with J-B weld-like compound but there's still leaking around the backside where the bracket is, an arean I can't get to without major cutting open the tank, etc. Any suggestion on it's repair or should I just replace the whole thing? Where can I find a replacement?
TDK
05-31-2005 19:56:34
 Re: auxillary tank repair / replacement in reply to Kevin Brooks, 05-31-2005 06:55:30
Seems a lot of develop leaks behind the bracket. You could seal it using a kit from Por-1 or Red Kote. Have a radiator shop repair it or buy the one from Cowman. I'd go with the least expensive option, which is most likely the latter. I couldn't find one at the time so I had to seal mine.
Nebraska Cowman
05-31-2005 08:58:27
i think I have an extra
