Need NAPA# for outer axle seal for Super C
N-vrything
05-31-2005 07:55:28
I am away from my Super C and was wondering if someone had the NAPA # or National Seal # for the outer axle.
CNKS
05-31-2005 08:50:44
 Re: Need NAPA# for outer axle seal for Super C in reply to N-vrything, 05-31-2005 07:55:28
If the outer seal is leaking oil, you also need to replace the inner seal. There isn't supposed to be oil between the inner and outer seals.
Nebraska Cowman
05-31-2005 08:44:26
23093 is the NAPA number cross from 358826R91
n-vrything
05-31-2005 10:36:58
 Re: Need NAPA# for outer axle seal for Super C in reply to Nebraska Cowman, 05-31-2005 08:44:26
Thanks for the help. If I do also need the inner seal might you also have the part# for it. Lots of thanks
MN Scott
05-31-2005 19:19:38
 Re: Need NAPA# for outer axle seal for Super C in reply to n-vrything, 05-31-2005 10:36:58
The inner seal is IH PN. 358774r91 that crosses to Napa CR 23708. There is also a felt washer that goes outside the outer seal IH PN. 351118R1. You would have to get that one from a CIH dealer.
Nebraska Cowman
05-31-2005 10:46:56
I'd have to look it up. let me know if you need more help.
