Order Farmall Cub Parts Online
Help newbe with a Cub and 1 bottom plow
Eric H
05-31-2005 12:11:41
I can't seem to keep the plow in the ground with my first pass just kinda skips across the top. Am I missing some adjustments for pitch or something? The plow is mounted for hydraulics and does not have any other adjustment handles. Any support would be kind. Thanks for ant help, Eric
Bigdog
05-31-2005 14:31:38
 Re: Help newbe with a Cub and 1 bottom plow in reply to Eric H, 05-31-2005 12:11:41
Check out these pictures. It sounds like you are missing the depth adjustment lever.
Nat
05-31-2005 12:57:31
Do you have the plow mounted correctly?
The drawbar needs to be turned around and mounted to the front holes in the final drives, and allowed to pivot up and down. There's supposed to be a depth control lever at the front of the platform on the right-hand side that pivots the drawbar up and down. The depth control lever controls the angle of the plow, and makes it dig into the ground.
