Governor and loader
Carlton
05-31-2005 21:37:24
on a farmall 300 is there an adjustment for the governor to get an increase in the rpms? Two on the loader the right side is always lower then the left and all looks good as far as the hookups on the loader,any possible suggestions?
Carlton
Clancy
Allan in NE
06-01-2005 05:13:45
 Re: Governor and loader in reply to Carlton, 05-31-2005 21:37:24
Hi Carlton,
I agree with the other guys; that loader is sprung. Somebody has abused it in the past.
Kinda common in loaders. :>(
Allan
Nebraska Cowman
06-01-2005 05:07:46
the pressure in your hoses should equalize. I'd say the loader is sprung.
Bob M
06-01-2005 05:06:56
Carlton - Low RPM is probably an adjustment problem in the linkage between the throttle handle and the governor. Try disconnecting the linkage at the governor input arm (the lever sticking up between the governor and the block). If you now can get full RPM’s by working the governor input arm by hand, readjust (lengthen) the linkage as required then reconnect.
If that doesn’t help, you’ll need to go inside the governor housing and look for an improperly adjusted high speed screw or possibly a weak governor spring.
The “right side low” problem with the loader says something is bent – probably a loader arm. Only fix is to straighten (or replace…) the bent parts.
