Super C axel seal HELP!
Andrew Z
06-01-2005 19:29:01
I"m trying to replace the axel bull gear seals on my Super C. Yet I am having trouble getting the axel off. I got the tranmision cover off and the bull gears are held in by two diffrent ways one a snap ring the other bolts. I removed the ring and yet the bull gear will not come off and there fore can not take the axel off. How do you get the bull gear off???
Thanks for the help Andrew
Wayne Swenson
06-01-2005 20:47:53
 Re: Super C axel seal HELP! in reply to Andrew Z, 06-01-2005 19:29:01
Put a large size nut against the end of the axle you are trying to remove and then pry against it using the opposite axle as a fulcrum point.
Axles are a tight fit on the splines so will not be easy to remove.
