radiator hose availability
Mickey Wathen
06-03-2005 08:32:05
I have been told my tractor is a Utility Int. Harv. model #330.Is there any way to determine this for sure? The ID plate riveted to the housing is unreadable except for the stamped numbers 4091.It has a C135 engine in it.The disc brakes are 5inches in diameter.I need an upper radiator hose for it and have been unable to find one.Can anyone please help me?
El Toro
06-03-2005 18:40:13
 Re: radiator hose availability in reply to Mickey Wathen, 06-03-2005 08:32:05
Send an email to bhershey@hoober.com with your tractor model number, the engine cid and list what hose or hoses you need. You can put them on a charge card if available and have them shipped to you if you have trouble locating them in your area. Hal
PAULIH300
06-03-2005 18:49:38
 Re: radiator hose availability in reply to El Toro, 06-03-2005 18:40:13
I can personally attest to the people at Hoobers....top notch,and they WILL reply to your e-mails.I have dealt with lousy dealers via e-mail,and I'm glad I tried/switched to them.With good,responsive service,they reap the rewards...and those other horrid outfits suffer.
Isnt it a shame though that out of hundreds of Case/IH dealers online,there seems to be only one that gives a darn? I think its high time CASE lets its customers rate their dealers performance (or lack of),and the better ones should get perks the lousy ones wont.
El Toro
06-04-2005 03:39:33
 Re: radiator hose availability in reply to PAULIH300, 06-03-2005 18:49:38
Hi Paul, They should take the Case/IH dealership
away from our local dealer. Hoober has 2 dealerships in PA and 2 in Delaware. They will go out of their way to help you. Hal
PAULIH300
06-04-2005 14:31:02
 Re: radiator hose availability in reply to El Toro, 06-04-2005 03:39:33
There is a....dare I say John Deere dealer near here...that has to be the worst.I have no reason to go there (thankfully!),but many who have call it the worst.No parts,nobody willing to look anything up (whats the part #?),and generally all they want to do is sell new.Usually customers wind up driving downstate or mail ordering.
Try your local dealer first? Nope.Wouldnt give it a thought.Isnt the internet a wonderful place to shop!
PAULIH300
06-03-2005 13:39:43
The hoses are short cut off pieces of straight hose.Measure them up (1-1/2"?) and head over to NAPA,Autozone,Parts Plus or other.....you will probably have to buy a 1 foot section of straight "Stick hose",but you wont have to change it again.Very rugged,long lasting hose....sorta like the original IH hose.(of course IH doesnt make its own hose....its sourced from Gates,GoodYear,Dayco or some other major manufacturer of rubber).
Nebraska Cowman
06-03-2005 14:58:12
 No it's not in reply to PAULIH300, 06-03-2005 13:39:43
Not on a 330 paul. It is a curved molded hose and bigger on the water pump end.
PAULIH300
06-03-2005 15:11:10
 Top hose is curved. in reply to Nebraska Cowman, 06-03-2005 14:58:12
I must have been looking at the wrong thing....the top hose is a 90 degree job with an enlarged end.
368600R1 top hose.
48827DA/370400R2 lower ends.
330U.
Michael Wathen
06-03-2005 15:21:51
 Re: Top hose is curved. in reply to PAULIH300, 06-03-2005 15:11:10
Is this the part number I need? 368600R1?
If so, where would you suggest I order it from?
Thanx.
Mickey
PAULIH300
06-03-2005 16:08:45
 Re: Top hose is curved. in reply to Michael Wathen, 06-03-2005 15:21:51
Thats the # for the upper curved hose for a 330U.A 340U may be different.
Nebraska Cowman
06-03-2005 15:27:13
Call my IH dealer in McCook NE 308 345-4890 Ask for John in parts, He'll mail you the hose if he can get it.
PAULIH300
06-03-2005 13:22:52
The 330 has "INTERNATIONAL" on the hood sides in a long stainless steel emblem,with "330" and "Utility" emblems on the front sides of the hood.The 340 used the same engine,but was seriously restyled.It got a squarer appearance,and the hydra Touch valves moved in location.
Nebraska Cowman
06-03-2005 09:33:56
must be cuz the 300 and 350 have the bigger motor. Oh my goodness, that is a molded hose isn't it? Did you try Case IH? failing that I would ask at auto parts stores. they make flex hoses that are larger on one end than the other.
