Bearing?
PAULIH300
06-03-2005 12:43:48
As posted by someone to one of my previous questions,there was mention of greaseable Throw out/pilot bearings on certain model tractors.He mentioned that H's and M's have externally greaseable bearings.Question is,does a 300U have the same convenience? Seeing as how a 300 is a reworked H in theory,you'd think it would be possible.But I'm not sure...
CNKS
06-03-2005 16:55:44
 Re: Bearing? in reply to PAULIH300, 06-03-2005 12:43:48
Your Operator's manual will tell you.
PAULIH300
06-03-2005 17:02:35
 Re: Bearing? in reply to CNKS, 06-03-2005 16:55:44
There is no mention so I guess its not accessable or even re greaseable.
iester
06-05-2005 06:38:02
 Re: Bearing? in reply to PAULIH300, 06-03-2005 17:02:35
Paul,my 350u has a grease fitting under the clutch cover plate on bottom of tractor.Remove two bolt's and there it is...Done't no on 300
