Order Farmall Cub Parts Online
Cub Clutch(Which way is right)
GNB
06-03-2005 18:49:36
I am going to be putting my clutch back on my cub . Which way does the clutch pad go on . I didnt pay attention when I removed it. IT looks the same on both sides except for the spline in center of pad which comes out about a inch or so and the other side is even with the pad. Thanks in advance.
GNB
Redned
06-03-2005 19:19:17
 Re: Cub Clutch(Which way is right) in reply to GNB, 06-03-2005 18:49:36
GNB,
Spline that is longer,goes to the direction of transmission.Always great to centerpunch parts with one of those automatic center punches. Also good practice to put bolts back in the holes after you remove something.Always to much down time looking for hardware and where did I put that screw?
john *.?-!.* cub owner
06-03-2005 19:15:28
long part of hub goes toward trans.
