M remote control hyd valve
makin' hay
06-04-2005 17:21:20
on an M remote hyd. valve there are 2 out [to hyd. ram] ports and 2 inlet ports. [from hyd. pump]one facing front and one toward engine. can either of these 2 inlet ports be fed from either of the 2 pressure lines off the hyd. pump ? as long as it is not fed off the delayed port ? i just got this setup at an auction and never had anything but a lift all with one port on ram. thanks.
DWV
06-05-2005 08:30:06
 Re: M remote control hyd valve in reply to makin' hay, 06-04-2005 17:21:20
If refering to the IH setup with belley pump and
IH remote control valve.The pressure port on right side of tractor was used and line run to port facing inside on remote control valve.Not all
remote control valves had 2 inlets drilled and tapped but if does either one would work and as long as pressure was sent to valve it wouldn't care where it came from.
