IT'S ALIVE!!!
jim in ny aka J
06-04-2005 17:36:20
been 2 weeks since I brought home my latest addition -a 1950 MD havent had alot of time to fool around with it but the suspence was killing me ! drained the 15 year old fuel didn't change filters yet might as well catch some crap with old ones won't run on gas yet think it needs plugs -buddy got zaped by mag HAHA so we hooked mta on front and went for a ride . went quite a ways lots of smoke but no run. was just about to stop and get the ether can when it fired and it runs like a top!! temp just nudges the green ,50 lbs oil pressure, tedded hay for 45 mins stayed right therethink I struck gold for 1500bucks!!!it willeven start with starter on diesel half hr after shutting itoff must have some compression!
RN
06-04-2005 19:57:35
 Re: IT'S ALIVE!!! in reply to jim in ny aka JYD, 06-04-2005 17:36:20
15 year old fuel? You probably will have to clean carb and check gas system for fouling/clogs. The old IHC gas start diesels need be run a bit on gas to full warm and before shutoff need to be allowed to idle few minutes. After shutoff set lever back to diesel mode to avoid gas/spark chamber valve from warping. From your description it sounds like you have a good head and valves, just a bit of gas system/carb fouling.
