Got new seat!
nc140man
06-05-2005 05:12:46
third party image
Just wanted You Guys to see where I'm at on My project! Got new seat and springs installed! Almost done with the rear or tractor! Just need to finish cleaning and repainting fast hitch parts and re-install! I've decided to keep fast-hitch instead of converting to 3 pt. Trying to keep originality intact and old hitch is in such good shape be shame not to keep! Now all I have to do is find some more fast hitch implements so I can play with it! 'Later, Scott
migraine
06-05-2005 07:47:32
 Re: Got new seat! in reply to nc140man, 06-05-2005 05:12:46
Are these all 1 point implements you are using? I have a 100 bought last year I have not started on yet but it came with a 1 bottom plow and a small rototiller with a 1 pt hitch. I don't know if this is just a fabrication but the guy said it worked good on the little 100. I think a carry cart would be very handy around the yard and field. Maybe the 1 pt prongs are still available. migraine
nc140man
06-05-2005 08:26:07
 Re: Got new seat! in reply to migraine, 06-05-2005 07:47:32
Yes they are! Wish I knew what happened Grandpa's old disc, I know He sold his finish mower years ago before He died. I use to have a sickle mower but traded that off for some dozer work when I built My new house. I borrowed a disc before and it and the plow work pretty slick on My 140! It was so easy to hook up and change to other implement by yourself! Just need to find some!
Hugh MacKay
06-05-2005 05:54:01
Scot: If you want some suggestions on fast hitch implements, send me an e mail. I have over the years fabricated many of my own. Some were 3 point conversions, while others I've built from ground up. I can e mail you some photos that may give you some ideas. I think you are wise keeping the fast hitch. I have fast for all 3 of my tractors SA, 130 and 140. I have a 3 point kit I can install, haven't use it in 35 years. Fast hitch just works so much better on those little tractors.
Tractor by the way is looking great, looks like you put some time into your restoration. Great little project these tractors, once you have them restored they don't break the bank account keeping them running.
nc140man
06-05-2005 06:32:20
 Re: Got new seat! in reply to Hugh MacKay, 06-05-2005 05:54:01
Thanks Hugh! I only have about 8acres and half of it is woods, mostly I think I need a decent disc,some kind of bush hog for the brush and keeping woods clean. I have about a 1 acre garden just for fun. I already have a 1-bottom flip plow? Not sure but it rotates over so You can keep sod going in same direction! I do have almost 3 acres of grass to keep cut! Might be nice to get a finish mower too! Well, that's for down the road, now just get the old girl fixed up! 'later, Scott
