Dishearted water in oil
iester
06-05-2005 06:47:49
Drained oil,noticed a little water..Removed beat up oil pan to replace..while cleaning old gasket from motor I noticed antifreeze dripping about every 10 minutes from center main cap is this a bad head gasket?
dej(JED)
06-06-2005 05:20:43
 Re: Dishearted water in oil in reply to iester, 06-05-2005 06:47:49
Pull it apart and quit wondering. There is no quick fix. If it is dripping antifreeze on the crank , it is a major problem.
gene (Missouri)
06-05-2005 14:47:45
Try a sealent made by Bars - local auto parts store. They have a sealent that will seal up cracks in blocks and head gaskets and is antifreeze compatable. It's only a few dollars, worth a try.
Gene
El Toro
06-05-2005 10:41:35
You should run the engine and look for bubbles in
the radiator. Could be a head gasket or a cracked head. Hal
Daniel Jessup
06-05-2005 10:04:47
sounds like the head gasket is bad. but ask your parts dealer and they can tell you something to look for when you pull of the top end of the motor
El Toro
06-05-2005 08:32:04
If that tractor has wet sleeves, the leak could be
coming from one of them, where they're sealed at the bottom. Hal
MN Scott
06-05-2005 07:14:00
What is the engine in? Gas diesel, need more information to help find a possable cause for the leak.
MAGMAN
06-05-2005 10:32:39
 Re: Dishearted water in oil in reply to MN Scott, 06-05-2005 07:14:00
Yes it has dry sleeves . Try the new head gasket in a bottle from silver seal or somthing like that. Its worth a try before you tear her down. Also you may want to do a pressure check. It may tell you more on where its coming from when looking from underneath. JON
iester
06-05-2005 09:50:50
It's a ih 350 utility 4 cyl 175 cid gas tractor.I can't tell where the antifreeze is coming from.thanks
