350D tach cable
Cotton Picker
06-06-2005 08:45:39
Where does the tach cable attach to on the motor?
skipper
06-07-2005 05:18:00
 Re: 350D tach cable in reply to Cotton Picker, 06-06-2005 08:45:39
I believe the early Corvetts had a tach drive generator. Course they would be Delco Remy. Perhaps some car buffs would have one around especially if others besides Corvette used it. Good Luck!! You will need all the leads you can get.
Merle Hoppenworth
06-06-2005 11:29:57
If you are having trouble finding the right generator Allis Chalmers used similar drives and generators some years.
DWV
06-06-2005 09:46:52
The original generator was made with tach drive on rear.
Cotton Picker
06-06-2005 11:35:08
 Re: 350D tach cable in reply to DWV, 06-06-2005 09:46:52
My generator must not be the original, is it an add on to the generator or a special generator? Never seen one. Where can you find one?
Seeing Red
06-06-2005 17:46:05
 Re: 350D tach cable in reply to Cotton Picker, 06-06-2005 11:35:08
Check to see if the shaft in the rear of the generator is threaded on the inside. If it is, then all you need is the tach drive housing and gears. Not an easy item to find, but not extinct either.
