Order Farmall Cub Parts Online
Belts for Cub
David Peters
06-06-2005 10:42:43
I'm looking to buy a new belt, which runs off the fly wheels, for my cub to run the grass cutter which is under the belly of the cub.
Anybody have any idea where I can obtain the belt and how much??
We are based in NC
Thanks, David
El Toro
06-06-2005 17:09:34
 Re: Belts for Cub in reply to David Peters , 06-06-2005 10:42:43
Take the mower model number and the old belt to your local auto parts store that sell Gates belts
and they can probably match it with a Gates. Hal
PS: If there's a number on the belt post it and
the mower model number.
Jim in NC
06-06-2005 10:54:23
Try Ari-supply in Garner, Greenville or Luumberton and Leinbach's in Winston. You will need to know what type mower you have on your tractor.
Bigdog
06-06-2005 10:46:56
It depends on which mower you are using. There are several brands of mowers which fit the cub. If you know the make and model of the mower, we may be able to help you. Or, you can measure the length of the old belt and find a replacement that way.
Bigdog
06-06-2005 10:47:01
