H tranny question
Wayne7
06-06-2005 19:00:47
I'm having to remove the countershaft from my H, The I&T manual says remove front bearing retainer nut, but it fails to tell me exactly how to do it, so does anybody have any advice?
jeff_MI
06-06-2005 20:15:27
 Re: H tranny question in reply to Wayne7, 06-06-2005 19:00:47
There's an access hole that allows you to get to the transmission-engine shaft coupling and the transmission-hydraulic pump coupling. If you remove the transmission-hydraulic coupling, there will be a slotted "nut" that is connected to the front of the countershaft - this is what needs to be removed. I may not have the best way of doing it, but I put the tractor in low gear, put a crowbar in the slot, and give a twist. I'm sure there's a tool for this, but I try to live life to the fullest and make do with what I have (tongue in cheek).
dupontsniper
06-08-2005 07:55:37
 Re: H tranny question in reply to jeff_MI, 06-06-2005 20:15:27
Hi, wayne7 gave a good route to going about it. We did same thing, used a long flat end pry bar in the slot and spun right off. If you end up needing and gears or shafts, let me know, I bought 2 complete rear ends and have more than enoughs good gears and shafts to one complete good trans and final. Shane
Wayne7
06-09-2005 09:13:53
 Re: H tranny question in reply to dupontsniper, 06-08-2005 07:55:37
The constant mesh gear needs replacing and so does third gear on the countershaft. A machine shop here said they could fix the gears, but if you have some for sale let me know.
