Questions about a C
Brian in NY
06-07-2005 05:56:51
Buddy of mine has a pretty clean old Farmall C with narrow front, good tin, paint, rubber etc....looks like a recent resto. She's wearin a woods belly mower that looks quite new; Her main problem is (I think) a crack in the block. Someone tried to patch it (it looks like they used two or three tubes of JB weld!), and according to my buddy it ran flawlessly until it started leaking. I only have taken a quick look at it, I plan to take a closer look some night this week.....but in the mean time....wondered if you fellas could give me a price range for the machine; and what do you think the mower might be worth? He doesn't know what the package is worth....but he said..."I'll just throw out a figure...and I know it might be high but tell me what you think....$1500 for the whole unit.."
OF course I used my best poker face, and said I would have to figure out just what is wrong with it before I decide if I am interested.
Well, that got me thinkin I better take a closer look at what is troubling the old girl.
Any advice on what to look for regarding the block patch? Thanks
Brian
Dale in Ar.
06-07-2005 08:46:31
 Re: Questions about a C in reply to Brian in NY, 06-07-2005 05:56:51
You wrote "According to my buddy it ran flawless untill it started leaking".Question,did it start running differently or did he mean that the leak was considered as the flaw ???If it started running differently,then there is an internal crack.If the leaking weld is the only problem,go for it.Offer the 1500 and be prepared to go a little higher,say maybe 2000.The old "C" is worth some where between 1500 and 2000, and as they said earlier,the woods is worth 1000.
RustyFarmall
06-07-2005 06:14:39
The Woods mower is worth at least $1,000, so take it from there. I'd say $1,500 for the unit wouldn't be too bad.
jal-SD
06-07-2005 07:15:10
 Re: Questions about a C in reply to RustyFarmall, 06-07-2005 06:14:39
If the crack is behind the carb, it can be repaired w/JB & won't give you any trouble. Neighbor has one that we fixed that way a while back, been running OK for a couple of years now, same application as you have. (My $0.02 worth. jal-SD)
