w6 engine removal
sjh
06-07-2005 12:31:42
Can someone explain how to remove the engine. I am not sure if I need to split the tractor in half becuase I cannot see the bolts for the back end.
Thanks
Scott
muggsw6
06-07-2005 13:30:01
 Re: w6 engine removal in reply to sjh, 06-07-2005 12:31:42
If you pull the clutch housing cover off you will find the rear motor mount bolts and also be able to get to the coupler between the clutch and trans.it"s not easy to get apart(coupler and clutch pivot) but if it were, everyone would do it! lol hope this helps,muggs
