Re: Super A with mid mount sickle mower
scotty
06-07-2005 12:45:49
The Super A is a great little tractor and will make a nice mowing machine with the mid mount mower. About a 6ft bar as is big as I would want on that machine. As far as pulling a spreader, it would have to be a smaller unit, since the tractor only weighs about 2300 lbs, and you only have about 18hp. You will want to check the side of the block behind the carb for any patches, the block often cracked there without antifreeze. How does it run, any unusual noise from the transmission, if you can get someone to do a compression test on all cylinders. How does the tractor look, was it abused? etc. Others may be able to offer more help!
scotty
Crude K
06-07-2005 13:11:43
 Re: Super A with mid mount sickle mower in reply to scotty, 06-07-2005 12:45:49
Scotty,
What do you think about the price?
scotty
06-08-2005 04:33:56
 Re: Super A with mid mount sickle mower in reply to Crude K, 06-07-2005 13:11:43
I think the price is a little high, but if everything is in good shape and the mower doesnt need any work, like new cutterbar or rockguards, probablly not too bad. You would want the tractor to have good paint and everything working correctly. I bought my Super A for $700 but have put a few bucks into it allready and not done yet. If your not sure, get someone else to go look at it with you!
scotty
