Static timing an IH 584 engine
coderbert
06-07-2005 18:04:58
Hey everyone!
I just finished installing a rebuilt D206 engine in an IH 584 tractor. I'm confused about static timing the engine. I have both the I&T manual, and IH's manual for engine rebuilding (this one:
Link
Both manuals say (as I understand it) to:
1.) turn the crankshaft (clockwise) until piston #1 is at the start of the compression stroke (BDC?) and the timing marks on the idle gear and timing gear line up
2.) continue turning the crankshaft until the 15 degree BTDC mark on the crankshaft pulley lines up with the timing pointer on the engine block (right underneath the timing window on the engine block)
3.) adjust the injection pump until the pointer lines up
My problem is that I can't tell where the 15 degree BTDC mark is on the crankshaft pulley. There are six holes on the back of the crankshaft pulley, but they don't seem to be numbered, nor are the holes numbered in the manual.
I've never worked on a diesel engine before, but I always thought 15 BTDC meant putting #1 piston at TDC and then tuning the crankshaft pulley back 15 degrees. I've tried this, but then I can't time the injection pump correctly (I set the timing mark on the injection pump, but none of the bolt holes line up to tighten down the pump).
Thank you for your time,
Michael
JB2
06-07-2005 19:08:45
 Re: Static timing an IH 584 engine in reply to coderbert, 06-07-2005 18:04:58
Hi Michael, on my brother's 684 (D239) the timing mark is a horizontal line scribed across the crankshaft pulley.
Are you sure you have the injection pump drive gear aligned to the proper timing mark. In my I&T shop service manual for 684,784,884, it says the injection pump drive gear is common to many engines and has 6 timing marks and for 684 (D239),784(D246),884(D268) use the mark by the number 4. Now for the 584 (D206) it may use a different timing mark.
JB2
coderbert
06-07-2005 19:18:21
 Re: Static timing an IH 584 engine in reply to JB2, 06-07-2005 19:08:45
Hey JB2,
Thanks for the fast reply!
I didn't see a horizontel line across the pulley, but I will check again tomorrow (I might end up taking the pulley off again).
> Are you sure you have the injection pump drive > gear aligned to the proper timing mark.
I think so--the gear has 6 numbers, and the manual said to set it to 2 for the 584. Good question, though.
Thanks,
Michael
JB2
06-07-2005 20:10:40
 Re: Static timing an IH 584 engine in reply to coderbert, 06-07-2005 19:18:21
Hi Michael, the D206 probably has a shorter stroke than D239 so would use a different timing mark on the gear.
Maybe you can get Bernard le mechano's attention.
I am sure he would know the correct setup.
Good luck
JB2
