fert box
tractor-ernie
06-07-2005 18:23:59
I recently got a ferilizer hopper that has a main set of gears on a platform for a two hole fertilzer box. Someone told me that it is for an old A and that the drive is a "right" drive (direct from the fertilizer to the right-side sprocket. The single chain that come with it is only @66" total, 30" working(double)).
Now, I have a 130 that I'd like to use it on which has a left drive. What can I do?
Can I put the box etc on the clutch housing and switch the left sprocket to the right side?
Jim Becker
06-07-2005 20:04:19
 Re: fert box in reply to tractor-ernie, 06-07-2005 18:23:59
If you have what I think you are describing, it will fit on the 130. I suppose if you have a Fast-Hitch, something may get in the way.
You need to have the entire attachment for an A, including the sprocket drive that bolts onto the final drive housing.
