W4 and H parts swap
ChadS
06-08-2005 07:43:42
Question,,,, Was the pinion bearing and holder in a W4, different than the H? I put a W4 ring n pinion in my H yesterday, and the pinion shaft did not go far enough back to properly mesh with the ring gear. I made shims to fix it, but just wondering if there is a difference in the parts compatibility in the bearing housings and shims. Chad
Paul A.
06-08-2005 10:09:31
 Re: W4 and H parts swap in reply to ChadS, 06-08-2005 07:43:42
Do you have the parts books for each? I thought both the 'H' and 'W4' had the same rear casting... If they do, they should fit okay. Chads, did you use just the 'W4'pinion shaft, or did you also use the 'W4' bearing cage too? You might've tried to use the 'H's bearing cage, just in case there is some difference - just something to try...
ChadS
06-08-2005 07:45:42
 also,,,, in reply to ChadS, 06-08-2005 07:43:42
I shimmed the pinion bearing forward, so the pinion shaft will go back farther and recut the snap ring clip groove inthe shaft was about .210 difference between the H and W4, I used the H pinion bearing, and holder,,,, Chad
DWV
06-08-2005 09:19:20
 Re: also,,,, in reply to ChadS, 06-08-2005 07:45:42
Yes,bearing housing different.The W4 housing in H would have worked.
ChadS
06-08-2005 15:45:05
 Re: also,,,, in reply to DWV, 06-08-2005 09:19:20
The H housing does work, long as I used the shim behind the bearing. I used brass, so it can have something that gives just a little for breaking it in. The shim fits tightly inside the H bearing housing, and moves the bearing forward about .210. The pinion shaft, no matter what, rides in this location, The pilot, or thrust bearing up front is still deep inside the constant mesh gear, and when installed, does not feel any different than when the H pinion was in it. The snap clip will keep it from moving forwards, and the brass shim will keep it from moving back. Hopefully,,,,, ,,,, LOL. The reason I did this swap is to take the tractor out of 4th gear while pulling, back to 3rd. A bit heavier looking gear set, and still be as fast as 4th. Always thought that this tractor was between gears in 3rd, and 4th, could handle alot more in 3rd. 4th gear,, well,, it will run, but still not working the engine the way I am hoping this will do by this swap. My old 4th, teeth was worn so sharp, it would kick out of gear, cause it was so tapered on one side of the gear. I did manage to find the perfect, "used" gear set to put in, just a little wear on 2nd and 3rd, but nothing to worry about, 4th was perfect. So, Im a step closer to getting it back together. I found, I like doing transmission work in the letter series Farmall's. Once they come apart, makes it alot easier to put back together! On the earlier post,, I just used the W4 pinion, and ring gear, used the H bearing cages,, when I got the gear set, I could have got them, but, I told him to keep what was left, Ill make it work...?? LOL! Thanks! Thought there was something different,,,,, Chad
