Pictures....Unknown parts of IH 330 Utility
Tweeter
06-09-2005 09:57:50
What is the smooth box behind the alternator? Do I need that for a 12Volt system? The red lever along the right side of the seat with the push button does nothing when I push/pull it.
PICTURES are located in the Parts & Pieces section of this site. Heading: IH 330 Utility
56owner
06-09-2005 19:35:31
 Re: Pictures....Unknown parts of IH 330 Utility in reply to Tweeter, 06-09-2005 09:57:50
The red lever is for engauging the PTO. The button on top, locks the lever in PTO run position. You should also be able to press the button and push the lever forward to stop the PTO.There is a brake in the system. The black box should not be needed if you install a 12 volt alternator with a built in regulator. I have a Chevrolet two prong alternator on my tractor. If you have any issues with overcharging try installing a oil pressure swithch and routing the wires through the switch. This will allow the battery to charge only when the oil pressure activates the switch.(running at above idle)
harnessbc
06-09-2005 11:33:28
..... the fellows are right, tweeter..... ..the lever is for operation of the pto..... .the button pushes in so that you can pull the lever up to engage the pto..... ..release the button to lock the pto on..... ...best wishes, bill
old
06-09-2005 10:15:04
That box is a regulator, and yep its a mopar alternator. Or if you don't understand mopar its dodge, LOL
TDK is right on about the lever by the way
TDK
06-09-2005 10:06:42
The lever is for the independent pto. Down is off/up is on.If it does nothing then the pto bands need adjusting or replaced most likely. The alt. looks like a Mopar unit to me. Not too familiar with Chryslers, but box could be regulator. Someone else on here will probably know.
