Starting/Running BN
Hank NWO
06-10-2005 18:52:13
I have a BN that is very difficult to start. When it does start, it runs very poorly and then stops. It has an aftermarket distributor (with new plug wires, timing checked and ok, points ok). Gas seems ok (strainers checked/replaced, gas line clear). I removed each plug to check for spark (all ok), and when I do remove a plug, the engine starts ok (!). I suspect a problem with the carb - it apparently has no mixture adjustment (without tearing it apart?). Also, when I do get it running, exhaust has blue smoke (bad rings?)
Any ideas? Why will it start with any of the spark plugs removed?
Thanks.
El Toro
06-11-2005 06:44:17
 Re: Starting/Running BN in reply to Hank NWO, 06-10-2005 18:52:13
I would check the valve lash and set them to .020"
until you get it running. Hal
Fred {Mudd} Hudson
06-11-2005 02:21:42
I have a B that I just went thru this with. I started with a carb kit after dippin the carb and rebuildin it ,nothin cahnged.after I replaced the spark plugs it ran a little better.I then got new parts fer the mag a coil , a condenser,points ,cap rotor and wires . I cleaned the mag and give it it's bithday presants and she is purrin like a kitten now. Hope this helps ya !!! Fred
Ohio H
06-10-2005 19:24:06
Pull the valve cover and check for a stuck valve. Just happened to me. A light tap with a rubber mallet did the trick.
