SA Restore begins
scott#2
06-11-2005 09:13:28
At last I finally get to start on this tractor,(now that its about 100 degrees out) This is a sweet little tractor, not a ding anywhere, runs great with a couple minor leaks. I am doing the electrolisis thing in a 60 gallon stock tank for paint and rust removal. WHAT A GREAT THING IT IS!!
I posted pics in the photo section and will try to get them in this post if anyones interested.
scott
Mike@NY
06-11-2005 17:24:39
 Re: SA Restore begins in reply to scott#2, 06-11-2005 09:13:28
Pretty good tractor you got there, will be even better after the restoration. I have a 49 SA and a 44 A I use, and there are a very handy tractor. As said, take your time, be carefull, and you will have a wonderfull piece of tractor history. Good luck!
Mike@NY
Dixieland
06-11-2005 10:39:23
Hi Scott, Well it looks like you got a good project there but if you ain't never done a restoration on one of these it takes a lot of time, patience, work, and some green stuff. I ain't never seen so many dadburn parts that has to be removed to do a complete restoration. If you ever need a little encouragement, post back.
Good luck and keep us posted.
scott#2
06-11-2005 12:46:31
 Re: SA Restore begins in reply to Dixieland, 06-11-2005 10:39:23
Yep, Im gonna do this one 99.9% right. Completly disassemble it, strip and repaint. I expect I will be done around the end of the year if I am lucky. I got real lucky with this one, original owner and low hours. Worst thing is it sat out.
scott
