Replacing knuckle in PTO
Working
06-13-2005 05:15:21
I have a 1100 (?) balanced head mower that has a knuckle outon the PTO shaft. This unit has no visible keeper - are they pressed in?
captaink
06-13-2005 06:30:39
 Re: Replacing knuckle in PTO in reply to Working , 06-13-2005 05:15:21
On my 1100 mower the snap ring keeper in in the inside of the yoke. Sometimes not easy to see or get out.
Working
06-13-2005 07:14:09
 Re: Replacing knuckle in PTO in reply to captaink, 06-13-2005 06:30:39
That might be my issue - guess I'll have to look a little closer and clean some grease up to see what I have.
Working
06-13-2005 10:55:07
 Re: Replacing knuckle in PTO in reply to Working , 06-13-2005 07:14:09
You were right, the keepers are on the inside and look like a real bugger to get off.
captaink
06-13-2005 11:21:04
 Re: Replacing knuckle in PTO in reply to Working, 06-13-2005 10:55:07
You are right, they are not the easiest to get apart. I squeeze the yoke in a vise using a ½” drive socket that is smaller in diameter than the bearing against one side in an attempt to push it over far enough to get the clip out. Usually I had the best luck by driving the clip off with a hammer and a punch until I could get something under the opposite side to pry it off with. After that it’s pretty much like any other universal joint.
Holler if you need more info.
Working
06-13-2005 13:25:07
 Re: Replacing knuckle in PTO in reply to captaink, 06-13-2005 11:21:04
Thanks for your help. I'll be hammering on it tonight, I'll post any adverse results in the morning. By the way, NAPA charged $11.00 for the new cross.
Allan in NE
06-13-2005 05:30:51
Hi Work,
Not familiar with your particular outfit, but it may be configured like GM's u-joints. From the factory, they are held in place by an internal ring of teflon.
What you do is, SLOWLY heat the cup area of the yoke with a torch and the stuff will boil out of a little bleed hole. When the teflon stops "worming" out of the bleed hole, you can then remove the cup in the usual way.
Clean the yoke up good; replacement cross cups are then held in place by the conventional internal C-clip.
DON'T HEAT THE YOKE TOO FAST! The darn things explode and shoot that cup across the shop like a bullet.
Allan
