hydro cylinders
len650
06-13-2005 10:18:16
Is there a place to get good quality cyl for a loader??
Thanks
janicholson
06-14-2005 09:28:32
 Re: hydro cylinders in reply to len650, 06-13-2005 10:18:16
Len650 The reason there are no responses is probably due to the lack of info. What type model application tractor hydraulic system and other questions.
There are litterally hunderds of hydraulic suppliers for industry/ag. Farm Fleet, TSC, and many others, including this site.
You will need length of stroke, size of cyl. bore, maximum load (push/pull for double acting)flow rate of your pump/system, max pressure of system, and mounting hole clevis configuration, and venting options for the "open side of a single acting cyl.
Good hunting, JimN
