Farmall M runs and dies
nositri
06-13-2005 13:58:23
I"m still tinkering with the old m. It seems like it will idle for several minutes fine and run fine for several minutes, but after a few minutes of driving if I take off in fifth and give it full throttle it will run for a few seconds and then start to sputter and then it dies. I try to turn it over and if I choke it, it will start, but immediately die and after a few minutes it will start up again. What do you all think. I"m thinking the fuel is getting cut off, but I want to be sure.
Hermit
06-13-2005 17:25:10
 Re: Farmall M runs and dies in reply to nositri, 06-13-2005 13:58:23
Don't forget to check the fuel cap vent.
deere herder
06-13-2005 16:29:18
Unscrew the base of the sediment bowl from the tank and check the stand pipe on it. It will most likely have spiderwebs or rust in it.It"ll give you fits till you clean it out.
old
06-13-2005 14:56:41
I'd say you have a clogged fuel system. Pull the drain plug out of the carb and see if you get a good flow of gas, if you don't you will need to check the sediment bowl filter etc
Farmall Don
06-13-2005 14:22:32
Did you clean the Carb. I"ve had that happen with a sticky float needle.
nositri
06-13-2005 15:09:13
 Re: Farmall M runs and dies in reply to Farmall Don, 06-13-2005 14:22:32
The carb has a new needle and seat.
RustyFarmall
06-13-2005 15:37:58
 Re: Farmall M runs and dies in reply to nositri, 06-13-2005 15:09:13
A new needle and seat is not enough, you need to completely disassemble the carb and soak it in carb cleaner overnight. In other words, completely overhaul the carb. Would also be a good idea to inspect the gas tank on the inside, it might be full of rust and other crud. While you're at it, remove the sediment bowl assembly and clean it good. If you don't like what you see in the sediment bowl, replace it. A new assembly is under $30.
