International 666
Hogman
06-13-2005 16:16:00
Hey guys what is the round tube do on the right hand sine of the motor in front of the oil filters.....My buddy has water in his oil.does this happen when the tube goes bad????? thanks for any answers.....Scott
K.B.-826
06-13-2005 16:33:27
 Re: International 666 in reply to Hogman, 06-13-2005 16:16:00
That"s the oil cooler. Usually when that goes bad, you end up with oil in the water, because the oil pressure is higher than the water pressure. You guys probably have cavitated sleeves, bad sleeve o-rings, or possibly a bad head gasket. You"ll need to get it to someone who can drop the oil pan and pressurize the cooling system to find the leak.
