Order Farmall Cub Parts Online
Pumping water with a Cub
Ken Jans
06-13-2005 19:20:19
My father talks about a pump that they used on the PTO of the old Cub we have. Does anybody know of such a pump that would work?
Illinois Boy
06-14-2005 09:24:31
 Re: Pumping water with a Cub in reply to Ken Jans, 06-13-2005 19:20:19
I would say that any pto ag pump would work. Hypro or Devalan - you can get them at TSC or Rural King. I think a 4 roller pump goes for about $60. You'll also need the PTO drive adapter that connects between the pto shaft and the pump shaft (about $16)
Make sure you match the pto speed to the pump - either 540 or 1000 rpm.
jal-SD
06-14-2005 14:12:04
 Re: Pumping water with a Cub in reply to Illinois Boy, 06-14-2005 09:24:31
I'm not sure, but I think the PTO on a Cub turns the opposite direction from what is considered normal. You might have to make some adjustments to make the pump turn in the right way to get suction. (My $0.02 worth. jal-SD)
