F-20 serial #
MDM
06-14-2005 10:37:37
I have come across a very clean F-20, where is the serial # located? The tin is in very good shape, tractor has the round spokes front and rear, tires are shot, carb and mag are there, has a belt pulley, overall, it is in very nice unrestored condition, motor is stuck, cant see any welds or breaks, I am not a Farmall guy, what else should I look for and what is the going price for an F-20 in this shape?
Sloroll
06-14-2005 10:44:22
 Re: F-20 serial # in reply to MDM, 06-14-2005 10:37:37
The serial # will be on the left side of the block stamped (not cast) onto a flat planed area on the upper rear. It will also be found stamped into the frame near and adjasent to the clutch bell housing. The actual data tag should be on the tool box under the fuel tank
