1970's International Remote Hydraulics
wolfman
06-14-2005 18:25:25
On the 1970 era International tractors-do you have to change anything to use a single acting hydraulic cylinder? I picked up a haybine with a single hose cylinder. Hooked the hose to one of the double outlets on my 664 and the other outlet leaked some. Switched the hose to the other outlet 7 it seemed to work better. Am I doing harm to the system? How about on an 826? Will mow some with it & the 656 too.
steve aeschlimana
06-15-2005 03:35:34
 Re: 1970's International Remote Hydraulics in reply to wolfman, 06-14-2005 18:25:25
hugh is right about putting the lever into float, there is a adjustment bolt below the base of the levers on most tractors that might need to be adjusted. steve
Allan in NE
06-14-2005 18:42:17
Wolfman,
Plug 'em in and go.
Allan
wolfman
06-14-2005 20:01:34
 Re: 1970's International Remote Hydraulics in reply to Allan in NE, 06-14-2005 18:42:17
Thanks Allan.
Hugh MacKay
06-15-2005 01:43:12
 Re: 1970's International Remote Hydraulics in reply to wolfman, 06-14-2005 20:01:34
wolfman: Just to add to what Allan has said, you must also put your hydraulic lever in float position when the hydraulics are down. If you leave lever in neutral position while working, the header will not follow land contours. Leaving it in ordinary double action down position puts presure on the unused outlet port.
