300 - 330 TA interchangability ????
RTGRAGE
06-16-2005 11:26:43
I"m wanting to know how interchangable the Torque Amps are for the 1950"s IH/Farmall.
I"ve got a 1957 330U and wondered if a earlier 300 or 350 TA would fit on the 330.
Thanks!!!
PAULIH300
06-17-2005 02:52:02
 Re: 300 - 330 TA interchangability ???? in reply to RTGRAGE, 06-16-2005 11:26:43
According to IH parts catalogs,they are different part #s.Not the same 330 vs 350.
RTGRAGE
06-16-2005 21:02:47
Anyone else want to chime in?
Hugh MacKay
06-17-2005 02:04:35
 Re: 300 - 330 TA interchangability ???? in reply to RTGRAGE, 06-16-2005 21:02:47
RTGRAGE: No point, you allready have the right answer. They could be exactly the same but until you go to parts book and compare, you can't be sure.
Aces
06-16-2005 15:48:12
RTGRAGE The main TA parts in side are the same, but input output shafts may not be cross shaft for the through out bearings may not be the through bearing for the TA are the same. I would think housing would not be. You will have to compare part numbers. To be sure.
