Farmall 544 fuel gauge
Chris in Washin
06-17-2005 10:54:20
I just put a new instrument cluster and wiring harness in my 544. The old fuel gauge hadn't worked for as long as I've owned the tractor. Now the new gauge reads correctly with the key turned off, and pegs on empty with the key turned on. Everything is wired correctly according to the wiring diagram, and the rest of electrical system works correctly. Any ideas?
K.B.-826
06-17-2005 20:17:14
 Re: Farmall 544 fuel gauge in reply to Chris in Washington, 06-17-2005 10:54:20
Chris, disconnect the wire at the sender, turn on the key, and see what happens. Now touch the wire to ground and see what happens. It should go all of the way one way or the other, most likely to "full". If that checks out, remove the sender from the tank (make sure the float isn"t full of fuel), reconnect the wire, hold the base of the sender against ground, and move the float through it"s range of motion. If the guage doesn"t move as you move the float, you"ve found that the sender is in fact bad.
Chris in Washington
06-18-2005 11:08:41
 Re: Farmall 544 fuel gauge in reply to K.B.-826, 06-17-2005 20:17:14
Thanks K.B., now why didn't I think of that?
Allan in NE
06-17-2005 11:08:27
Chris,
When dealing with fuel gauges, troubles "ALMOST ALWAYS" are with the sender and/or it's wiring.
Pegging on empty tells me that you have an open circuit somewhere. Again, probably at that darned sender (bad wiper) or it's ground.
Forget about the reading with the key off. That is nothing more than gravity working on the needle swing apparatus.
Allan
Chris in Washington
06-17-2005 11:38:16
 Re: Farmall 544 fuel gauge in reply to Allan in NE, 06-17-2005 11:08:27
Thanks Allan
