350 ute clutch housing
iester
06-17-2005 18:45:11
Were the TA clutch rod goes through the clutch housing there is slack.When I pull back on TA lever I can see the rod raise slitely..My book doesn't show a bushing Is there a way to fix this?? Thank's Lester
Aces
06-18-2005 10:38:02
 Re: 350 ute clutch housing in reply to iester, 06-17-2005 18:45:11
iester If the hole on the other side is not to bad you could come through from the other side and line ream it out to a standard size bushing, then put in oilite bushing.
