F20 stuck rear end
Nebraska Cowman
06-18-2005 16:44:14
You'd think afetr all the 20s and regulars I've had apart I'd seen it all? Well here is a new one. Brought a narrow-tread 20 around to take a tire off and it rolls fine. But when i jacked up one side I can't turn the wheel. You suppose someone pinned the differential? I'm hoping it it just stuck with rust but here in this dry country they are never rusty inside.
r4etired
06-18-2005 19:07:51
 Re: F20 stuck rear end in reply to Nebraska Cowman, 06-18-2005 16:44:14
I would jack up the other wheel and see if it will turn.I was unloading one down the ramps and a broken rivet in the brake locked the right rear wheel, it spun sideways and broke the front pedistal when it hit the concrete.Made for an expensive parts tractor
RAW in IA
06-18-2005 18:52:46
One would think it wuld be almost impossible to turn a corner if the diff. didn't work.
