350 ute drain holes
iester
06-18-2005 17:05:32
What seals do I replace to stop fluid from leaking out of drain holes on tranny? Thank's Lester
JLE
06-18-2005 17:29:00
 Re: 350 ute drain holes in reply to iester, 06-18-2005 17:05:32
There are three seals, one on the upper PTO shaft,
one on the TA carrier, and one on the input shaft to the TA.
iester
06-18-2005 19:18:36
 Re: 350 ute drain holes in reply to JLE, 06-18-2005 17:29:00
Thank's JLE,Is taking out TA and associated parts hard to do?? Any supprises??
JAS
06-19-2005 18:47:37
 Re: 350 ute drain holes in reply to iester, 06-18-2005 19:18:36
JLE,I have a 300U with same problem,but have noTA.
Where do you recommend finding the seals and other parts needed. This is 1st tractor I have owned in about 20 years. I do have some manuals.I also am going to replace clutch assy.
Thanks
JLE
06-19-2005 03:13:28
It's not that hard, would have a manual at hand, even after R/R many TA's still have to check the manual once and a while. The one thing you have to watch very close is the seal at the TA carrier, they have tool for installing, but have done many without. Jim
