TD9 B motor
bulldog2185
06-18-2005 20:36:07
I have a TD9 B series International Dozer. I blew a piston out the side of the block. I am looking for a new motor or at least a block. The only markings I could fin on the motor are as follows. TD9B 9M 14346 Could someone tell me if this is the engine model or where to look for the engine model or for that matter what the engine model is.
Allan/NCA
06-19-2005 19:23:16
 Re: TD9 B motor in reply to bulldog2185, 06-18-2005 20:36:07
They used the 282 on the 560 660 656 706 TD 6 62 series TD 9 92 series plus many industial series tractors. These are 6cyl diesel motor, but the B was also turbo charged. You should be able to find a replacement motor fairly easly. Allan
Tractor Tom
06-19-2005 08:50:25
I am just learning enough about TD-9"s to know there were several engine models and I don"t have a parts book to help you. But- I do know people who can:>Link
Go>Link to the IH construction forum, there are lots of guys (& gals) who can "decode" that part number. Also, get your serial number off the ID plate located on the firewall inside the operator compartment.
hector gemme
06-19-2005 02:41:19
HI I have some td9 use parts,is it a 4or 6 cylinder.
